Hi,
m/b: Rampage III Extreme
cpu: i7 990X
gpu: asus 590gtx
2 SSDs in Raid 0 (using 3Gb/s Intel controller)
watercooled, but not yet overclocked (except memory running at XMP)
Looking for suggestions as how to get to the bottom of this error. PC seems fine, but after a bit (hour+) you will get bsod. Things I have tried
- all drivers are upto date (the usual advice when you google this issue)
- ran memtest86, and passed
I don't believe it's an over heating issue, haven't seen a record cpu temp above the 30's, I was also able to complete 3dMark.
Keen to get the system stable before I up the gpu clocks
Are there other programs I should be trying?
Is there more information that would be useful to give?
I also suspect Win8 as pretty much all the hardware is Win7 era (but then everyone blames Microsoft) so was wondering if I should give up and use Win7?
cpu: i7 990X
gpu: asus 590gtx
