Clocking 8800GTX
14 Dec 2004
South
Im currently on 660 core, shader linked around 1512 and ram 1013.
Should I keep the core and shader linked?
If I put the ram high than 1013 it seems to just die, but other people are quoting 2050?
Leave the core set the 648, unlink them and increase the shader, should make it to 1600-1650 or more unless your unlucky.
2050 will be the DDR rate of the RAM, so 1025 on your slider.
Thats not true, it will be 2016(1008)
edit: Ahh, neverimind. I see what your replying to.
rodders, just leave the memory set to 1008(2016), memory on 8800GTX's doesnt usually go much further.
I've managed 660/1625/2050 out of my GTX. Any higher and I get lockups, I've unlinked my shaders to try and get more out of the card.
