- 5 Feb 2009
Had my i2500k/Asus P8Z68-V/gen3 setup for a couple of weeks now and still really sussing out the new methods for overclocking, taking things slowly and so on. Still, one thing has had me a bit concerned.
Basically, I started clocking using offset voltage (so the vcore could drop at idle) and left it on auto. I worked my way to 4.2GHz in smallish steps and all seemed well with idle and load voltages and temperatures.
But then I noticed something odd. Whilst full load volts were okay (1.30v load), there were also weird spikes just as the system went from idle to load. Even if there wasn't time for the clocks to ramp up, the voltage still would. At 4.2GHz it would spike at 1.36v! At 4.3, 1.368v! I didn't want to push much further.
I'm now using high LLC and manual negative offset voltages (-0.015 currently). This has taken the spikes right down to 1.336v, which is okay, but load volts are now higher and I clearly can't push the negative offset much further before the idle voltage drops too low.
Anyone else noticed this weird idle-to-load brief vcore spike? Is this a potential reason so many SB chips died? Is it something to be concerned about?
I wouldn't even have noticed but for coincidentally glancing at CPU-Z at the right time. Anyone found any other solutions?
