hi guys im clocking my 805 all i've done is up my fsb (see my sig) my mem is set to 400 and voltages are still stock. temps r good barely breaking the 40C mark....just wondering what next?? up the memory or the fsb somemore cheers guys
A.N.Other said:http://tomshardware.co.uk/2006/05/10/dual_41_ghz_cores_uk/
Read, follow, enjoy results. Obviously, you don't have to go a far as they did - and it probably wouldn't be wise to do so tbh.
techmonkey said:Yeah, I read that article. It looks like the thread poster would need h2O cooling for anything over 3.6GHz.
Raikiri said:Complete crap, 3.8ghz here on an arctic freezer 7 pro that never reaches it's max speed (47c both cores 100% load)
david.n.c said:could you let me in on your settings and setup m8
Raikiri said:RAM ratios are on the same screen as the FSB is, you keep them as the same value for 1:1 on this board.
Try increasing the CPU voltage to 1.45v first and see how high you can go before it gets unstable.
4Qman said:These chips are awsome, get some screenies up if thats ok dude.
Yeah id just go easy and see whats the best balance of voltage and speed without pushing it too harsh. Then again i would wana see what it can do.
Arthalen said:I hit 3.6 on air, limited by the motherboards output of heat to the back of it - damn stackcool technology.... grrrrr ...
