Clone mobile Android for PC use.
30 Sep 2008
Is anyone aware of it's possible to clone an android based mobile O/S (Samsung with Knox) & then say mount that image into an Android emulator running in Windows?
I expect I'd be asked for the pin/pattern like each time i turn on the phone & instead of using my finger print within secured apps just 'use pattern instead' prompt.
These are all sound like Android gaming platforms or just screen sharing. I'm taking about making an image, a backup of the entire phone, then running that image in windows. You're essentially cloning the phone.
