Cloning SSD boot drive
Caporegime
25 Jul 2003
FR+UK
Just wondering if anyone knows of any good software I can use to clone one SSD to another, it is a system boot disk.
Or..as its a boot disk am I just best off reinstalling the O/S?
Hiren's Boot CD, use Seagate Discwizard - press ALT + T + O + K at the first prompt when it loads up to bypass the lockout.
I'd recommend you don't do a direct clone, and go for a fresh install of Windows 7 instead though. Cloning from a HDD will mean TRIM isn't enabled, reducing the life of the drive.
Just use the built in image tool from the backup & restore centre on Windows 7 or alternatively the free version of Macrium reflect.
He already has an SSD. It is possible to manually enable TRIM.
Its for a Windows Server, so the free version of that won't work. I'll have a look at the Windows Tool tonight, though I'll likely just end up rebuilding.
