Closer to target: Please check spec v2
27 Jan 2006
A few changes to earlier config. I need confirmation that the swiftech will work with AM2, but I'm anticipating whatever Intel do with Conroe, AMD will better within a year on AM2, and my next minor upgrade will be in about a years time. I don't want to be stuck with then-obsolete DDR1 and 939. I can justify a £250 CPU in a years time to the missus much easier than I can a new MB/RAM/CPU combo 8)
Thoughts?
HD-078-SE Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE)
£59.95 £119.90
CA-009-TT Thermaltake VA7000SWA Shark Aluminium Full Tower - Silver (CA-009-TT)
£69.95 £69.95
WC-014-SW Swiftech H20-220 Apex "Ultra" Watercooling Kit (Socket 462/478/LGA775/754/939/940) (WC-014-SW)
£128.95 £128.95
CA-009-TG Tagan TG580-U15 580W ATX2.01 Easycon SLi Compliant Modular Silent PSU (CA-009-TG)
£69.95 £69.95
CD-032-NE NEC ND4571 16x16 DVD±RW Dual Layer LabelFlash ReWriter (Silver) - OEM (CD-032-NE)
£24.95 £24.95
CP-167-AM AMD Athlon 64 X2 Dual Core 4000+ 2.00GHz (Socket AM2) - Retail (CP-167-AM)
£194.95 £194.95
MB-142-AS Asus M2N32-SLi-DLX nForce 590 SLi (Socket AM2) PCI-Express DDR2 Motherboard (MB-142-AS)
£114.95 £114.95
MY-011-GS G.Skill 2GB DDR2 ZX PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBZX) (MY-011-GS)
£149.95 £149.95
GX-039-GW Gainward BLISS GeForce 7950 GX2 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-039-GW)
£349.95 £349.95
Subtotal £1,223.50
VAT £214.12
Total £1,437.62
or save £90 and take the IceQ 1900XT 512Mb.
I'd look at going for the 570 SLI motherboard instead, saves you some cash and makes buggery all difference to what you get (look at the feature comparison charts on Anandtech or DailyTech).
Apart from that it looks like a good spec. Not sure about the 7950 as I havn't heard anything about it yet.
