Cloud solutions with a management system
27 Mar 2004
Between Realities
We are looking to use a Cloud solution where I'm working.
We want to be able to put files online, and have our clients view them.
We need to beable to:-
Upload large files: Each file will be 8mb or smaller, but there will be many.
Management options(Delete files, Restrict access, Delete\allow access rights for individuals)
We essentially require an AD style solution for cloud based storage. We have looked around and notice Dropbox do offer a good business management system. But it's rather pricey.
Anyone got any other alternatives?
Thanks
We're on OwnCloud at work now, seems to be pretty good. You do have to have a server or web space somewhere though.
We did use OneDrive but it got worse and worse with syncing problems.
https://duetapp.com/
this might not be what you're after but it's worth mentioning as it's a little more 'featured' than say owncloud (which I'm looking to install on my nas at some point) because it's more collaboration orientated.
It does need your own server but I'd assume you use your web host or similar.
Might also be worth looking at the options on softaculous (project management section)
