Cloudy water
28 Dec 2003
Hmm
Filled a new loop to start leak testing and the water's turned cloudy with minute air bubbles and doesn't seem to want to clear. If I turn the pump off then the cloudiness disappears after about a minute to leave perfectly clear water but, as soon as I turn the pump back on, it clouds back up straight away.
How long should I have to leave the loop running for the water to clear? What else could be causing this?
Loop consists of:
DDC 3.2 pump
D-Tek Fuzion block
Swiftech MCR220 rad
Swiftech MC-RES
If the water clears, it's just little bubbles in the water which will clear over time but it can take hours to do so. Just leave it running overnight and see if they're gone in the morning.
