No you would need a SAN if you wanted to implement shared storage. You could connect multiple NAS boxes to your LAN and setup shares from the server pointing to locations on the NAS boxes though.
Ok DFS won't work because you can't have 2 link names the same.
I need storage that's easily upgradable but I need to ability to combine all the drives into one. RAID is the obvious solution but it's not easily upgradable, you would need to restore the array in order to upgrade.
Very very bad idea, what is it your trying to do anyway and what type of data are you looking at storing?
If you were going to do it properly which you should specially if its for a production environment is too used either fiber attached SAN's or ISCSI preferably using something from the HP Storageworks range.
Using Windows software raid to span multiple external attached disks is utter madness to be fair.
I'd rather have a pc with a few 500gig drives over raid 5 than those external drvies. Pop linux on it and you've got a fairly decent nas kind of thing.
