Hi.
I was able to get clustering working a while back - great!
I am now trying to recreate it and write step by step instructions but failing at somepoint....
basically I believe to heve done everything exactly the same. The problem is about the disks.
I am using iSCSI (Starwind software). And when I just tested the failover, it is reporting that the Quorom configuration: Node and Disk Majority (Cluster Disk 1) - warning: Failure of a node or "Cluster Disk 1" will cause the cluster to fail.
any ideas what/where I would be going wrong here? I see 2/3 disks in my computer on the other node. not sure why....
