- 17 Jun 2005
- Near Brighton
Ok well my clutch went earlier this evening on my mk2 106 1998, 1.1 40700 miles. now ive only owned the car for just over 6 months and ive done about 4k in it. is it unusual for a clutch to go that quick? I drive it kinda hard i guess, not thrashing it to complete death. sometimes il rev it quite high then let the clutch up if i need to get away out of a juction quick. here is my post from my car club forums, apolgies for the bits that arnt relevant.
Was meeting people near the pet place in eastbourne for the convoy to stanma park. We left, just driving out the car park, felt a bit judery (sp) so i revved it a bit more kept going, just about to go on to the main road bit, and i heard this sorta groaning noise. got out, talked to Chris (owns the black almera (sp)) he said make sure the gear is enganged, so i tried it again same happened. Talked to ollie and are mate behind, decided to carry on.
So gave it a lot of wellie and managed to get going, gear changes while moving seem to be fine, got to the first round about, managed to keep cruising just about. was going along the dual carriage way and it seemed to go a bit slower but gear changes from like 2nd to 5th seemed ok. Approaching the round about, started slowing, tried to change gear just wouldnt go in (neutral position was the only 1). managed to keep rolling off the roundabout in to a bus stop. Rod appeared, martyn, chris and ollie all came back to the bus stop. Then rang my dad and he appeared and drove it back with no clutch.
So yeh, my poor car. hes not completly sure whats wrong with the clutch tho, he thought it was a bit odd for a car only covered 40700 miles. I may have driven it a little hard maybe, but noting serious i dont think.
(release bearing?)
it decided one evening that it's clutch was going to play up with similar symptoms (stuck in 2nd gear) turned out the clutch cable had become un-adjusted. Maybe it just need re-adjusting?
