Clutch question
18 Oct 2002
Bedfordshire
Ok I'm having an argument with a friend about clutches.
I say that if you have your car in gear waiting to pull off with the clutch down it doesn't wear the clutch.
My friend says it does and always has it in neutral when waiting at traffic lights or roundabouts.
Who is right?
Wouldn't be wearing on the clutch itself but probably wouldn't do wonders for something mechanical. I also put it in neutral when stopping for 10seconds or more.
they both disconnect the driveshaft from the engine
but iirc holding it in gear with the clutch depressed will result in the clutch constantly fighting the drive, and wear the release bearing. though not the pressure plate as that wont be touching anything
Doesn't wear the clutch plate (obviously). But it does wear the release bearing and possibly other related linkage points...
as everyone else says.
its not good practice.
it isn't expensive, but getting it replaced is if you can't do it.
not an easy place to get too.
