CM-690 II Advanced Fan Setup
22 May 2007
Hi Guys,
I currently have this case:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-257-CM
However, I've noticed recently that it seems to be getting very warm in there. I have added no additional fans than the ones it comes with (one at front, 1 at top, 1 at back), and have not changed the configuration at all.
I was wondering if anyone could give some advice on fan setup for this as I'm looking to add some more.
Inside I have a i5 4670k overclocked to 4.6ghz, cooled by a matterhorn Pure. Also have 7950 Twin Frozr III.
Thanks in advance!
I've got 1 up top, 1 front bottom, 1 back top (for the h50), 1 bottom. All conected to a Zalman fan controller.
How warm does it get? Mine gets quite warm but thats a water cooled cpu with the same gpu as yourself, 4 hdds, 1ssd and an OD.
Temperatures of the CPU and GPU are fine, it just seems that sometimes my GPU is at ridiculous fan speed when plaiyng some games, and holding my hand over the top reveals a lot of hot air being churned out!
I'm guessing the bottom fan sucks in air, is that a good addition?
