Hi guys im looking for a replacement front fan for my CM-690 II Advanced something that pushes more air thru the case as the one that comes with the case dosent push a lot of air.
I think that fan has 120mm mounting holes, there are 120mm and 140mm mounts in the front of your case, but it might be worth checking if the overhang will clash with anything because I seem to remember the 120 mounting holes aren't centered with the 140 mounts...
the 690 can take 140 or 120 at the front,2x120mm on the top and 1 at the back. if you dont 4 fans in your case then thats the first thing to do. changing one fan when you only have 1/2 in them is not going to change much.
