I was bored and found the old dremel so though why not have some fun and start my first ever proper mod with a windowed side panel for my new 690 II. ( I never had the balls to cut up the 800D )
My first time using a dremmel not too bad i think, i hope. I'm planning on getting some clear acrylic and sticking it to the inner side, but as you can see it pic no. 3 there is not much space at the top bit to stick it down. Reckon it will be sufficient just using the other 3 sides?
I tried to do some rounded edges, but failed so just ended up "rounding" one of them with a sanding peice thingy. It's not finished and ill post some finished pics tomorrow if i can get a hold of some acrylic tomorrow (doubtfull)
I am also thinking of spraying the front mesh, drive bays, hard drive thingies and possibly the GPU heat shroud thing as i have a spare from the 570 that died. Don't know what it would look like as i have a blue gigabyte motherboard but i cannot stand blue!
Any suggestions?
Some pics,
Any suggestions?
Some pics,
