CM Aquagate S1 Maintenance
6 Mar 2010
Ipswich, Suffolk
Hey Folks,
Currently working on a system with a Coolermaster Aquagate S1 CPU Watercooler installed. The user is reporting loud noises after a full rebuild of the system where I replaced the CPU and refitted the cooler. I simply removed the bracket, repasted the new CPU and reapplied the cooler.
My experience with Coolermaster kit is limited and wondered if anyone has prior experience with the kit and could shed some light on the way forward.
I'm assuming blowing out dust from the radiator, refilling and/or draining the reservoir would be a good start?
Thanks in advance!
What sort of noises?
I'd remove the fan, clean the rad and check the fan isn't dead before replacing the coolant (purely because it's an easier fix)
