CM ATCS 640 modding services
4 Dec 2008
Hi.
I'd like to do some mods with my chasis.
I want to take off part of HDD's cage and put 240 Rad at the bottom of the case - so I need to cut some part of it.I bought Dremel300 rotary tool , but I think it is not enough to do all mods.
Do enybody knows someone within Scotland who doing things like that?
I planning powder coating as well.
Any help?
Nop it is too high to fit in this place.
or...............
Huh it is a good idea - make a little whole at the bottom of the case and put rad horizontaly - but I'm quite sure that RX240 won't fit - I have 250 EK res over there and rad will be to fat.
BTW is Phobya good make - or rubbish?
You could fit it by using a xspc drive bay. This would create a lot of space as you can fit the pump in the res. Haven't used Phobya so can't comment on qulaity.
theres a couple out there. The 1 i am talking about has no pump but you can fit your current pump in it. It comes in two flavours either for 1 or 2 pumps both are dual bays. Oh and its black like our case:p
Off topic but have you found the clear side pannel for the 640, they don't even stock it anymore in dutch parts shop
