CM HAF 922 push pull case mod
26 Dec 2020
Hello everybody i have a cooler master HAF 922 case that is configured with a push pull 240 aio to keep up with the overclock. Does anyone have any ideas on how to make that look nicer with a side cover to hide the brown without obstructing airflow? I was thinking maybe a 120 to 140 fan converter that just sits over the 120 mm fans to hide the sides . just for the top outside fans.thanks so much
wNYcQrY
W5cDX6c
wNYcQrY
W5cDX6c
I've had the HAF 922 since it came out new so it's a bit dated now. I did some mods in the tray area to take another intake but I've got bored now and my Corsair 5000d Airflow is arriving today.
The HAF has been faultless over the years I'll probably still use it with an old retro build with a socket 939 board and Radeon X850XT.
Here's the fan mod I did at the front using Thermaltake ARGB fans....
That is very impressive. Yeah I ask how you went about mountain the top 200 mm up there as well I ended up buying two triple 5.2 drive phase to house 80mm not too as above the noctua 200 mm on the bottom of mine. I would love to be able to DM you and ask a couple questions if possible and how you went about that thanks so much in advance have a great day
