Hi,
I just finished fitting my Hyper 212+. I've had a look at the temperatures (I haven't really had a look at temperatures prior to fitting this) and I'm slightly confused by this:
As you can see, there is a ~ 10c difference between these two. On my previous CPU and HSF there was about 4.
In addition, the CPU is reaching about 58 on the core under load. It's currently at stock.
I don't think I've fitted it wrong and I have reseated it several times.
Specs are:
NZXT M59
Phenom II X4 965
DFI Lan Party 790FXB-M2RSH AM2+
4GB G.Skill DDR2 2400 @ 800mhz
2 x Sapphire Ati Radeon HD 5750
Western Digital 500gb + WD 320gb
TX650W
Any ideas?
Thanks in advance.
EDIT: Load temps:
http://i.imgur.com/hvkKP.png
PS: I'm assuming hotlinking to images hosted on imgur is fine?
EDIT 2: Problem with temperatures solved by setting "CPU FAN TO MAX >" to 35c. It was previously on 55. The variance between core and mobo cpu temperature readouts was causing the fan to never go higher than 800rpm. It's now happily at 50c with the fan at 1700rpm under Prime 95 blend.
Specs are:
NZXT M59
Phenom II X4 965
TX650W
Any ideas?
Thanks in advance.
EDIT: Load temps:
