CM quickfire TK issue with Osx
21 Oct 2002
UK
Hi all,
Hi, I have a CM Quickfire TK and use it with osx. The keyboard works as intended except for the number pad. I can't seem to get it to work. The buttons work as their secondary functions (pgup, pgdn etc) but I can’t get the numbers/ enter to register. Pressing the numlock key does nothing (no led). All other keys/ backlighting/ media keys work fine.
Am I missing something obvious such as a key combination or is it just an issue using it with osx? I have emailed CM directly but am still waiting for an answer so thought I’d try here too.
Pressing NUMLK is all you have to do to switch between numpad and other functions, a quick google shows that this is an issue with OSX.
