CM Silencio S600 & Phantek P600S - alternatives?
6 Jan 2006
Hi all, I'm looking for a replacement for my Coolermaster CM-690 Dominator [2009 vintage ;-) ]. I was about to build a new i5-10600k and Z490 combo in it but realised things have moved on and it might be a good time to get a new case.
So... I've been looking at the Coolermaster Silencio S600 which seems to fit my needs. Are there any similar midi tower cases I should consider? I'm not well informed about what are good quality brands.
No fixed budget but something below £100-120 would be good. I don't need a window (no RGB) and intend to use an AIO cooler (not sure which one yet, sorry). 1 HDD and 2 SSDs. Graphics card will eventually be a Nvidia 3080. ATX mobo.
All suggestions welcome! Thank you.
Looks like the Phanteks Eclipse P600S is one for the shortlist. I was a bit worried about one purchaser saying that a lack of HDD mount rubber gromits makes the HDD vibrations go through the case though. Has anyone else got that case?
I just built a system in an R6, I mainly bought it over the R7 because of a few things on the 7 I didn't quite like. Its excellent. The only thing I don't like is the modular vent at the top, removing the top cover from the mesh is a pain and easy to bend slightly. The only other let down is that the fans in the case are 3 pin, and therefore not PWM. They aren't loud, I just don't understand why they didn't make them 4 pin. Otherwise it is a really nice case. The R7 has some improvements in key areas, and a few bits like the vent pattern that didn't quick work for me.
Tons of options/room for expansion, GPU length is no longer even a problem in the 'open' configuration, and some nice touches like the sound insulation.
