CM Stacker 830 and Scythe Ninja Plus
31 Aug 2006
Stafford
Hi, does anyone have any idea whether or not the Ninja will fit in a CMS 830? Please don't shun me for owning such a case :(
Ok shunning aside, yes. :p
Not sure if it would go with a full bank of fans, but considering how excessively large the case is it should have no trouble.
I do have the side panel full with 4 120mm fans, it doesn't seem to be very large width wise though.
Should be fine, the cooler fits in most cases very easily, most of which are considerably smaller.
On a side note I am also a Tom L and born a couple of months later, uncanny.
