Hi all,
I'm using:
Asus P5N32-E Sli motherboard (using its daughterboard for sound, think it's called the supreme-fx)
Coolermaster Stacker 830 case, with the front panel connector connected to that card
Vista 64 Ultimate
Additionally:
BIOS settings: Sound on that slot (can't remember the wording) is set to AC'97 rather than HD. The cable from the case to that card is also the AC'97 one.
Sound works fine from the cable on the back of the case (plugged right into the card). But there is nothing from the front panel at all. I also can't find a way to choose what outputs to use.
Has anyone used either of these products and knows something I may be doing wrong? Would quite like to use the front panel connectors instead of rummaging behind the machine to plug in my headset each time!
I'm using:
Vista 64 Ultimate
Additionally:
