CM Stacker Mods
10 Apr 2004
It was due for a good clean, so I modded it instead :p
It uses: one cardboard box.
It basically is a fan pointing straight at X1900, this was done by removing the cover and screwing through the holes, lines up PERFECTLY!!! Also the shroud around CPU fan to stop hot air being re-circulated.
Temps:
http://www.thunder-keep.co.uk/overclockers/temps.jpg
X2 = down from 48-52C to 42-45C
X1900XT core = down from 62/63C load to 57/58.
X1900XT env = 38/39C down to 34/35C
X1900XT pwm = 55C down to 50C
Chipset = down from 32/34C to 30/32C
PWM = down from 33/35C to 30/32C
Yes, wires ARE messy, but it doesnt matter cos you cant see it ;)
All in all, ready for summer!!
Conc
Loud, as long as I cant hear it when playing a game then its all good :D
I think at 62C the fan on the X1900 goes to 60%, then I can bearly hear it :)
Doesnt pass 58 now tho LOL
Conc
I had the same idea as you, I've got a fan blu-tac'd to the bottom blowing air straight up from the bottom.
Jokester
My X2 does not output any heat into the case, so all is good there, graphics card has a zalman 700 jobby on it and its the highest component in the case that gets affected by heat, and its heat just dissipates through the roof and top holes in the v1000.
Hard drives are in there own compartment with a 5v fan, and I have a 5v fan at the back as a intake.
The joys of silence :D
