CM Stacker RC-810 Question
Caporegime
18 Oct 2002
Lake District
Due to the size of the case and the placement of the PSU in the bottom, will wire lengths on the PSU pose a problem when reacing drives mounted in the top 5.25" bays?
Planning on using an iGreen PSU.
Nope, as long as power cables are long enough. PSU is a Enermax Liberty.
CM 810 make a good server case? Planning to stick 5 removable hdd caddies in and an optical drive.
Does it come with the castors?
Will standard sata cables reach the top bay of the case? From your pic (if those are standard cables) it looks like they will.
Yes easily. The SATA cable from the top bay , where the HD connector would be (one down from front panel 5.25") just reaches the edge of the PSU PCI-E connectors, not that'll you plug it in there of course, but shows SATA cables are long enough
