Hi Guys
We now have stock of the fantastic Quickfire TK Keyboard from CM Storm that uses Cherry MX Brown Switches.
The Brown switch is the most popular switch type at OcUK currently and demand for this keyboard has been high in recent weeks.
stock is limited but we have plenty to go round at the moment
CM Storm Quickfire TK Mechanical Keyboard - Brown Switch @ £68.99 inc VAT
You're a gamer. You know that a mechanical keyboard means the difference between winning and losing. The original QuickFire Rapid gaming keyboard was embraced by gamers worldwide because it made the difference. Now the QuickFire TK takes the QuickFire Rapid and put it on steroids! Choose between 3 different Cherry MX switches. Each keycap is UV coated to make it durable. There's full LED backlighting with 3 modes and 5 brightness levels. NKRO over USB means every single keystroke will be registered. An embedded steel plate give you maximum stability and durability. 7 easy-access multimedia shortcut keys save time. A complete numpad lets you get work done while not gaming. The slim and lightweight size gives you plenty of room for your mouse. Great for LAN parties.
Features:-
- Brown Cherry MX Switch
- Compact layout with integrated Num pad block
- Full LED backlight, with 3 modes and 5 brightness levels
- NKRO over USB for unlimited simultaneous keystrokes
- Embedded steel plate for maximum stability and durability
- Super Grip pads and Keyboard stand-offs with rubber feet
- Windows keys can be disabled
- 7 easy-access multimedia shortcuts
- Detachable braided USB cable and cable routing groves at the underside of the keyboard
Specification:-
- Keycaps: ABS, grip coated, removable
- Keycap Puller: Yes, ring-puller
- Backlighting: All keys, Red, 5 Levels, 3 Modes
- Interface: USB 2.0 full speed
- USB Cable: 1.8m, braided, gold plated, removable
- Weight: 544 g/1.2 lbs
- Dimensions: 377.5(L) x 138(W) x 33(H) mm
Only £68.99 inc VAT.
ORDER NOW
Features:-
Specification:-
ORDER NOW
