CM Storm Scout Case
23 Mar 2010
ok....so i was planning on getting this but i dont know whats bad about it....
some people dislike it ....and some people do....
IMO i like it....first time i saw it , it looked awsome....but dont exactly know what its disadvantages are.
so can someone list the advantages and disadvantages?....
personally i think its choice of looks you either like it or you dont i like it but chose a cm690 due to price had no problems with it either somebody whos got one will tell you more
Hi,
I have this case and am selling it. Only reason i am selling it is i want something bigger inside as i want to do some one off stuff. Its a really nice case , very stylish and great for cooling.
Matt
I'm doing a build currently with this case, you might want to have a gander
http://forums.overclockers.co.uk/showthread.php?t=18129256
Pros: Nice black interior, i personally quite like the look, good cooling, nice sturdy handle.
Cons: It is quite cramped inside, if your planning to route a 8 pin atx cable round the back of the mobo tray and through the hole at the top you will need and extension cable as it wont reach.
Overall a good case, but if you planning anything big maybe not best choice. After about 6 months of use im also on the look out for a bigger case.
