Hi guys, I'm planning on buying the white CM Storm Scout II (HERE) for an upcoming build.
The case comes with 2 white LED 120mm fans mounted in the front and a single 120mm fan in the back. The front fan LEDs are controlled by the LED switch on the top.
I want to replace all the included fans with Corsair AF120s or SP120s, undecided as of yet. However, I want to add some BitFenix LED strips and I want them to be controlled by the LED on/off switch on the case. If I were to have 2 LED strips, would it be a simple swap out from the included LED fans to the LED strips?
