Hi Guys
We have an exclusive keycap set for the novatouch shipping with all novatouch keyboards.
There are 15 sets of these available!
This includes new WASD keys, windows keys and a space bar.
For anyone who has already had a Novatouch from us, please contact sales with your order number and refer to this thread and we will ship a set out to you, free of charge!
Epic!
CM Storm NovaTouch TKL Hybrid Capacitive Switch Mechanical Keyboard - FREE SNIPER ELITE 3 GAME @ £149.99 inc VAT
The Cooler Master NovaTouch TKL provides the ultimate typing experience for all - including the eSports professional and the expert typist. To achieve this, the NovaTouch TKL uses a Japanese made hybrid capacitive switch with a uniform 45 gram actuation force and a 1mm actuation point. This Cooler Master exclusive unique switch has an ultra smooth press, a tactile trigger point, and a rapid debounce time. The debounce time is 3x faster than traditional mechanical switches, allowing Actions per Minute (APM) to not be hindered by hardware limitations. Additionally, the switch is designed with a custom stem that is fully compatible with Cherry MX keycaps for keyboard customization enthusiasts.
The Novatouch TKL features Hybrid capacitive switches, this combines a mechanical spring based switch and an electrostatic capacitive sensor that provides uncompromised tactile feedback as well as promoting excellent typing comfort and durability. These capacitive switches have no physical mechanical coupling which actually eliminates switch bounce and sensor chatter as there is less friction on each keystroke than a regular mechanical switch.
Cooler Master has integrated the stem design from the popular Cherry MX switch types to allow Novatouch users to customise their board using aftermarket keycaps or O-Ring dampers.
Features:
- Japanese made hybrid capacitive switch
- CM exclusive compatibility with CHERRY MX Keycaps
- Ultra smooth, tactile key presses
- 45G actuation force / 1mm actuation point
- On-the-fly Repeat Rate Adjustments
- N-Key Rollover & Anti-Ghosting
Specification:
- Key Switch: Hybrid Capacitive with Cherry MX Keycap compatibility
- Form Factor: Tenkeyless (TKL)
- Key Rollover: NKRO (Windows Only)
- Polling Rate: 1000hz/1mS
- Interface: Micro USB2.0
- USB Cable: Removable, 1.8m Braided, 18k Gold Plated Connectors
- UK ISO Layout
Only £149.99 inc VAT.
ORDER NOW
Epic!
Features:
Specification:
- UK ISO Layout
ORDER NOW
