CM Storm Trooper fan controller
14 Sep 2012
Behind you
I've been searching Google for a few days now and can't find any info on the built in fan controller on the trooper. I would like to no how many fans it can handle ( or max load )
I've got 10 fans in total, 6 on one rad and 4 on another, I have connected them to it just to try and they all work, but I'm worried that after a longer period could there be any problems with it being over loaded ?
I have found out that I should be ok with 9, 3 on each connector. With the vipers being only 0.17 amp and the each connection being capable of 1 amp. I read somewhere on Google that a guy has 9 apachee's and they are 0.33 amps and he has bee running like that for 6 months. So I should be safe enough
