CM110 -how to clean?
Don
21 Oct 2002
Parts Unknown
Taken apart my system, its been over 2 years since i put the watercooling in, and its MINGING
so taken it all apart, got a few mud marks etc on my cm110, whats the best way to clean it? -using household stuff..
was thinking fairy liquid + cloth, then vegetable oil + cloth?
some peoples sweat can be very corrsive to aluminum, leaving prints that are very hard to remove. wear powder free latex gloves when handling your case.
Warm soapy water with a soft cloth and then polish dry with a soft cloth
Pics please once it's all cleaned up
soapy water (fairy liquid i used) works really well :)
once i've finished putting ALL back together, il'l post pics!
A small amount of baby oil on a lint free cloth works well for removing finger marks etc. and maintaining the anodized finish.
if youve take everything out and its a empty shell,
get some of that computer spray foam cleaner you can get let it foam up as per instuctions and then wait and wipe residue clean :D
