cm690 case modding
19 Jul 2007
notts , uk
i have the coolermaster cm690 case and with my psu being longer i need to cut the slot where the psu cables go through to hide them , what will i need to cut the case and what can i get to put around the edge of the new hole to stop the psu cables from getting damaged (gromet or like) . and where can i get it
you will see the hole infront of the psu is not long enough , idea's please
You'll need a dremel or something with a cutting disc. You'll then need some u channel edging to finish it off. Ocuk don't sell uchannel but if you google it you'll find some.
Tbh if you don't need to much send me a trust mail with your address and i'll get a bit sent to you. I have a little left from my old builds.
i purchased it from ocuk last year , it's the "PC POWER & COOLING Silencer 750 Quad CF RED" , which ocuk no longer sell (shame its looks good and performs well also)
http://www.pcpower.com/power-supply/silencer-750-quad-crossfire.html
