Has anyone here actually mounted a 240mm radiator in the designated space at the bottom of this case? I have the case, have the rad, but the mounting holes are too far apart (it's like they're for a 280mm rad, except a 280mm rad is too long to fit - the case feet get in the way). The only way that I can see of doing it is to screw the 240mm rad directly to the grill. This is less than ideal, and would mean using washers - as well as not being able to use the included dust filter.
Anyone have any thoughts?
