CM690 II PSU Cover Mod
13 Sep 2012
Hi All,
I vaguely remember a member on the forums doing a build in the same case titled and he had some sort of PSU cover which was the length of the case and two fans built on this bit of metal.
I remember he mentioned it was purchased online but I cannot remember where and can't find a site. Searched throughout the forum but also cannot find the thread!!.
Can anyone help? :confused:
most metal fabricators could do this
try find someone local. bit of scrap stainless. someone would should do it cheap.
Dg, will take some measurements after holiday and have a look around locally thank you for the tip :)
freddie, waheey that's the one good find matey! :)
