My Antec build has been running perfectly for a month, all hardware is perfect and cooling is great etc.
Recently whenever I switch off the PC and then switch off the mains all my settings reset - Date, Time, BIOS Settings (everything to do with what the CMOS Battery helps with).
It only happens when Mains power is stopped, so If I do an average shut down it is fine.
I have tried this:
-Replace CMOS Battery(About 6 times)
-Pull CMOS Battery holder's little metal contact higher so that it is definately in contact with Battery
-Pull 12-pin and 4-pin connectors out and replace batter
-Remove batter for 20 Minutes and replace
-BIOS Update
-Different Power Supply
I know it's probably the motherboard being a pain, but everything else about the motherboard is spot on.
This isn't an urgent thing, it's just a minor annoyance. I would prefer to have the freedom to switch off the mains without having to reset EVERY setting.
Thanks in advance.
I have tried this:
-BIOS Update
Thanks in advance.
