Hi i have the Corsair vengence pro 2 x 16gb 32Gb Kit rated as: 1600 MHz / 16-18-18-36-54 / 1.35 V
Advice for overclocking?
Thaiphoon Burner tells me this:
Manufacturer
Corsair
Series
Vengeance RGB PRO
Part Number
CMW32GX4M2C3200C16
Serial Number
Undefined
JEDEC DIMM Label
16GB 2Rx8 PC4-2133P-UB0-10
Architecture
DDR4 SDRAM UDIMM
Speed Grade
DDR4-2133P downbin
Capacity
16 GB (16 components)
Organization
2048M x64 (2 ranks)
Register Model
N/A
Manufacturing Date
Undefined
Manufacturing Location
Taiwan
Revision / Raw Card
0000h / B0 (8 layers)
DRAM COMPONENTS
Manufacturer
Samsung
Part Number
K4A8G085W[B/C/D]-BCPB
Package
Standard Monolithic 78-ball FBGA
Die Density / Count
8 Gb / 1 die
Composition
1024Mb x8 (64Mb x8 x 16 banks)
Input Clock Frequency
1067 MHz (0.938 ns)
Minimum Timing Delays
15-15-15-36-50
Read Latencies Supported
24T, 23T, 22T, 21T, 20T, 19T, 18T...
Supply Voltage
1.20 V
XMP Certified
XMP Extreme
Not programmed
SPD Revision
1.0 / January 2014
XMP Revision
2.0 / December 2013
Manufacturer
Corsair
Series
Vengeance RGB PRO
Part Number
CMW32GX4M2C3200C16
Serial Number
Undefined
JEDEC DIMM Label
Architecture
DDR4 SDRAM UDIMM
Speed Grade
DDR4-2133P downbin
Capacity
Organization
2048M x64 (2 ranks)
Register Model
N/A
Manufacturing Date
Undefined
Taiwan
Revision / Raw Card
DRAM COMPONENTS
Manufacturer
Samsung
Part Number
Package
Die Density / Count
8 Gb / 1 die
Composition
1067 MHz (0.938 ns)
15-15-15-36-50
Supply Voltage
1.20 V
XMP Certified
XMP Extreme
Not programmed
SPD Revision
1.0 / January 2014
XMP Revision
2.0 / December 2013
