CNC/ Laser cutting side panel services?
4 Oct 2014
Hi all,
I have a .dmg file of a side panel I'd like cut out of a sheet of see through acrylic for my case.
Now I'm quite the noob to this; does anyone offer services in the UK to do this?
i'm also interested in this.. would be good to make a couple custom panels for my case... i could use a jigsaw but obviously laser cut would be a lot cleaner
There's a link to a guy does custom acrylic reservoirs etc
In one of the sub forums
Would assume he can do a side panel too
Since it's still CNC acrylic
Though it might not be cheap
Will see if I can remember where it is
There's also a couple of forum members have CNC machine
But the names totally slipped my memory
Here's the link
But still can't remember the members with CNC machine
You could try post asking if someone has one
Perhaps in the wanted section if you have access to MM
http://www.productdesignfoundry.com/
Edit here's a sample of the work
They did for forum member
https://imgur.com/gallery/Brd994O
Edit 2
That cost £250 including next day delivery
But obviously it's way thicker acrylic than a side panel
And more complicated to make
That price is pretty much standard for that sort of reservoir
If you look at work by radikult
For stuff bigger than I can cut on my own machines I’ve used the acrylic store.
They can do laser or routing up to full sheet size depending on what you need.
