- 15 Dec 2003
- Bedford/Derby, UK
Thinking of buying a secondhand or cheap server....
mainly to host my e-mails and domain... (to take over from my home pc), but also thinking about it possibly being a website hosting server for people to use, obviously to pay me for...
I dont think i'd be buying a server or hosting it anywhere if i can't get people to host a site on it, as i dont think i could afford to do it.
Ive found some co-location hosting at £39/month with £15 setup - 300GB traffic 10ips 99.97% uptime etc... in maidenhead.
sounds a good deal - for a 1u server.
I expect to be looking for at least, a dual pIII 1ghz, 2gb RAM spec server with ample hdd space - most likely sata. (cheaper disks).... and this is most likely overkill.... not sure though... - would most likely be windows based, as i know nothing else, and can be easier to manage (vpn / rdp).....
Any ideas? or suggestions?
Any ideas for cheap servers either reconditioned or used? probably around £500ish.
Also, to get people to know about the server - whats the best way to advertise it before setting things in motion?
And one final thing, roughly how many concurrent website sessions / max sites would that server handle? - (bearing in mind it could be running x amount of sites with my mail server software too.)
Thanks,
Alex
Thanks,
Alex
