Coarsair PSU quick question
Bald-Eagle22 said:
{snip}Just ordered the above and before i upgrade my current rigg to an SLI 8800 will the Corsair HX 620W ATX2.2 Modular SLI Compliant PSU fitt into my Antec P180 ?{snip}
The case IS ATX standard/format & so is the Tagan PSU :rolleyes:
There was no need for that was there?
Did it occur to you that he might be on about the P180s lack of space around the PSU and so he was asking if it would fit ok?
Yep I'm pretty sure that is the reason he asked....
It does fit but I'd connect ** modular cables in before screwing in the PSU as space is limited
