Cockpit Self Portraits
9 Jan 2005
Canada
Hi guys,
Am looking for advise on the above. I need a clamp so I can attach the camera to the instrument panel. This is the only possible way it can be done as the FOD rule states it must be firmly attached. Is there a device I could buy which would help me achieve the shot I desire?
Also, as we will be going through basic manoeuvres it will need to withstand a small amount a G-force +3.5/4 to -3.5/4.
Any help will be much appreciated.
King.
Manfrotto Magic Arm and Superclamp...
I have 2 and they can be incredibly useful. You can position them pretty much wherever you like, and the clamp will clamp onto most things, especially good on round bar/tube. Cost ~£120 ish new, but ~£50 on eBay.
The lever to the left locks/unlocks the movement of both ball joints at the ends and the pivot in the middle. I imagine it'd be easily enough for what you want.
/edit:
What camera/lens?
Brian Shul *Ex-SR-71 pilot and author and photographer of Sled Driver* used velcro on the camera and on the cockpit surfaces to take his shots I believe.
However - that was in the SR-71 and there was virtually no G loading.
What are you doing to get G loading that low though? -4 is a large negative G load. Usually limits are around -3g
*Dammit - aerospace system emgineering coming back to haunt me...*
Simon/~Flibster
I was giving the extremes. Just in case. I know -4 is far fetched. ;)
The velcro sounds like a good idea. Will pop to the shops and test it out in the car. I will be using a 18 - 70 mm DX lens. Probarbly set to f10/11 on Aperture Priority. ISO 400 to cover any loss of light.
Fingers cross it will be accepted. Would love a big picture of myself all geared up on the wall.
Gets to the drawing board,...
King.
