8 Mar 2009 at 22:51 #1 Gustov Gustov Soldato Joined 30 May 2008 Posts 7,788 After reading through some cod posts i thought I'd go ahead and install my 2nd favorite game of all time Cod 2 However i went to install it and it just comes up with Access is denied. Any suggestions? Edit- It's a 100% legit copy Last edited: 8 Mar 2009
8 Mar 2009 at 23:56 #3 Cybermyk Cybermyk Soldato Joined 31 May 2005 Posts 6,847 Location Peoples Republik of Teesside I'll give the install a go later I have 64bit though. The game uses a flash installer? maybe you need to install that first.
9 Mar 2009 at 00:03 #4 slambo69 slambo69 Soldato Joined 28 Feb 2006 Posts 3,819 Location London I installed this game yesterday with no problems with vista 32 bit. Not sure what the problem could be though.
9 Mar 2009 at 07:41 #5 Puppetmaster Puppetmaster Soldato Joined 17 Jun 2005 Posts 6,515 Location Near Brighton is uac turned on? if so try turning that off maybe?
9 Mar 2009 at 09:17 #6 Gustov Gustov Soldato OP Joined 30 May 2008 Posts 7,788 Tried both suggestions and nope
9 Mar 2009 at 09:21 #7 Gustov Gustov Soldato OP Joined 30 May 2008 Posts 7,788 looks to be sorted i had to explore the CD and run the exe file from there
