COD 4 best class setup ?
18 Oct 2002
Nottingham
Hello,
Just wanting to see peoples views on the best custom class setup ?
Which weapons and perks to select ?
Thanks
M16 with Red Dot, Fragx3 for Perk1, More Damgage(Can't remmeber name of perk) for Perk 2 and Deep Penetration or Martydom for Perk 3
Great combo for just about any Map.
P90 with silencer, uav jammer for stealthy maps and Big ass LMG with that extra explosive damaga perk for Shipment
I've got several depending on the map.
off the top of my head (and if i remember correctly) my three favourites are currently:
1. G3 + red dot; USP; Claymores; Juggernaught; Penetration
2. M4 + red dot; USP; Claymores; Martyr.
3. M4 + silencer; USP + silencer; Jammer.
The last class I call Stealth :p
Looking forward to level 37 when I can get a G36 :)
My preffered gun is the G36C assualt rifle. Perk 1 - x 3 Grenades. Perk 2 - More bullet damage. Perk 3 - Martydom (drop grenade when killed)
Shotgun I love to but there is only shipment that it's worth using :(
G36C is ok, definately the best automatic assualt rifle but the G3 is only any good when using the ACOG scope on big open maps like Bog
And vacant, you missing loads of kills not using it there.
Personally I dont think there is a best class set up. I use all the weapons for the 1000 odd bonus's. Plus you get better at weapons that way.
I like the G36C but it's fairly underpowered. Its accurate but certainly the M14 is better at the job imo.
If i'm playing when I've already used the guns/bonus's I use the M4 or M16. Deep impact and penetration. I then also have the same guns set with Martydom instead of penetration and with claymores. This I use on shipment or headquaters.
I then have a shotgun set up with martydom and a stealth set up which I rarely use with a silenced G36C.
RPD + Grip, Stopping Power, Deep Impact. That's probably my most used setup.
I change my other setups around regularly, Stopping Power is probably the only constant, I use that with everything but the shotguns.
I was using the M16 all the time when i just got the game, with stopping power, 3 special/frags, matrydom/deep impact depending on map.
Nowve gotten slightly better i use a barrett 50cal whenever i can with claymore/stopping/iron lungs. The other sets i change around often, if i see someone doing really well with a certain set i'll try that, etc.
Favourite set at the moment is MP5+silencer/3 frags or stuns/stopping power/extreme conditioning
Double tap or stopping power??
To my mind they both do almost the same thing.
Double tap fires more bullets which in effect causes more damage, but is it more than stopping power. This also assumes you hit with the extra bullets!
Possibly its a trade off, the extra bullets combined cause more damage than stopping power but only if you hit with all of them
