Cod 4 mouse sensitivity grrrrrrrr!
11 Mar 2008
Norn Iron
Ok ever since i got my microsoft habu mouse ive been having an absolute nightmare in COD4, my sensitivity is either all over the shop i.e i can do a full turn in about 1cm movement of the mouse, or its moving a pointer through treacle.
Has anyone else found the adjustment to a hyper sensitive mouse a nightmare? i can adjust sensitivity on the fly yet theres none of the settings which offer me a happy medium between reaction time and accuracy.
Heres hoping someone else has a simialr mouse and has a decent setup for cod4 they can share. For example how far is the sensitivity slider on the options menu in COD4 mines at 50%
Tryed adjusting the windows mouse settings sensitivity ?
Can't say I have the problem you have with my diamondback 3g @ 1800dpi, even if I do, I just adjust the sensitivity ingame with the razer software.
I think i suffer from the same problem as you with all Manufacturer drivers, it makes the mouse feel over accelerated.
Try using it minus the drivers as a "Standard HID-compliant mouse" i know it may sound a little wierd but it works for me ;)
