COD2 EAX3 Won't stay set???
8 Jun 2006
Hertfordshire
Hope this is the right place to post?
Got Vista RC1 installed (no issues) I have an XFi Xtreme card and want to set 'sound provider' within COD2 'sound' to 'Creative EAX3'.............
I set it and then apply, game restarts and when I go back it's reset itself to 2D???
I have add/remove Creative drivers and still the same, looked at sound settings within control panel and they look fine?
Device manger see's everything? I have Goole'd but found no help, Anyone else seen this or know a fix :confused: :confused:
i think its an issue with the x-fi drivers for vista
EDIT: Are you running it in game mode (the xfi card)
Yes I am mate, and I tried it with RC2 and thats the same, I also saw the posts about openal but no info on when this will actually take affect :confused:
so tempted to go back to XP pro until these bits are sorted out
i agree stick with XP Pro.i couldnt even install vista rc2 on this comp it got to the "install" bit and it never ever moved :( xp installed fine. danm bill gates to hell.
Openal F.T.W?
Foxor-
