COD4 changing settings problem
8 Feb 2008
Edinburgh
Whenever I try to change the settings in multi player COD4 the game closes and I get this error message.
I can't find the readme file :confused: I bought it off Steam and just can't find the readme. Does anyone know how to change the settings in multi player without it messing up?
I had a bug, where I couldn't change the games' resolution, without it crashing, and that was without xfire installed.
You can change the settings manually by finding the COD4 program directory, then go:
COD4/players/profiles/yournameprofile/config.cfg
and editing the text file there. Not sure if it'll work for brightness. If its there, it'll be around the seta r_...
can u adjust brightness by itself? leavin the AA out of the equation?
when u try to change AA settings in CoD4 it should tell u that the game needs to restart in order for the changes to take place,,,, im guessing this doesnt happpen?
What GFX card do u have?
