hope someone can help with this
We run several cod4 servers, stream to punkbuster and all that stuff and were collecting info about stopping cheats including capturing demos which is good for seeing those really fast aimbot hax.
anyway someone found the following info (part of it):
righto, that seems ok except there is no keybind for the backspace key in the info so this won't work (doesn't work)?
can anyone explain the code that goes in the cfg file, i dont know what vsrt is?
does anyone know how to get that setup at all? or recommend any kind of binds for starting and stopping demo record?
Recording a demo
Whilst in game, you can pull up your console and type /record demoname
You will see a little counter at bottom left of your screen showing you the recording kbs counting up.
To stop recording, open console again and type /stoprecord
A much easier way to do this is to add the following code to your config_mp.cfg file found in your player profile folder.
Code:
//Easy one button demo recording function using the backspace key
seta demo_start "record; set demo_tog vstr demo_stop"
seta demo_stop "stoprecord; set demo_tog vstr demo_start"
seta demo_tog "vstr demo_start"
When using this config method of recording by pressing the backspace key to start recording and pressing it again to stop recording, your demos will be named 'demo0000.dm_1 / demo0001.dm_1 and so on.
