COD4 Help - NFITWR :( :( :(
8 Oct 2005
Midlands, UK
Bloody hell. This has suddenly got a lot harder on the last level - No fighting in the war room, mainly due to the lack of check points :(
I have a check point at the bottom of the 1st set of stairs and all is well. However, I'll spend a few minutes killing loads of enemies along the next part only to get owned at the start of the next section and to start all over again. Do I even get another checkpoint?
Have had a good 10 tries now :( :(
10 tries, lol. I had between 100-150. You get the first checkpoint at the stairs and the next after clearing the box room. You have to get there with about 6 minutes left to checkpoint IIRC. Then the next one is about 3 minutes.
hmm, so I'm standing at the first checkpoint on the stairs and the next room is long hallway (can see the entrance) from bottom of stairs. Is this the room your talking about - as i cleared that room out and didnt get a checkpoint at all?
In the hallway there is a turning on the right, go down there and empty the box room all the way down. When you get to the end of the box room turn left and back onto the hallway (there should be some more enemies over to the left) and as you reach the entrance to the next tunnel you will checkpoint (if you reach it in the right amount of time - about 6 mins remaining)
Yeah I did this yesterday, and had to have several goes, as some of the checkpoints didnt register until the 2nd/3rd time I got past it, quite annoying have to do the same bits again and again.
Ah bugger. I'm soo dumb sometimes. Just read the bit about how the checkpoints depend on your time.
Anyone got any good ideas how to clear the long hallway bit after the stairs?
take out the initial 2 guys in the hallway as quick as possible, then make sure you kill the guy in the right hand turn straight away (or he WILL kill you). then you can basically fire all the way down the box room through the gap in the boxes taking out about 3 or 4 of them, just be very cautious but sprint whenever you can to activate the checkpoint.
Oh, and if you think this bit is hard wait until you get to the final tunnels on this level :p
I went left and used the grenade launcher. Lob grenades over the top after cooking one. After a couple of tries you learn where they are. I got through there in seconds then.
Trust me you aint even at the hard bit yet :D
achieve360points.com has some video play throughs on vet, it took me an age to get through this level but i did eventually.
spent a couple of hours trying to get to the end of said corriddor then when i eventually did i got all the to the war room itself in one go.
War Room is easy. Isn't it Danny.
When you get to the stairs with the Star on the wall, run over, pick up the flashbangs, shoot the first person you see and run to the left, shoot the person at the end, force your way through the left hand side (don't worry about the ones on your right half-way through) once you get to the end, shoot the 3 on the opposite side, then run through to the end (on the left).
You should have around 6 minutes on the clock, preferably more.
Hehe thats exactly what i did a few minutes ago. I'm now at the checkpoint after the hallway room with 6:09 on the clock. Wish i'd have noticed those flash bangs on by the stairs though :(
I'm at the entrance to a narrow corridor with a blockade at the end and very narrow corridors leading two rooms either side. However, there are two gay lords waiting at either end.
Just to put my mind at rest, if you get the checkpoints, your on track to finish?
Good, this seems like an epic level to end a truly epic game. If it was easy i'd be kinda disappointed, as there are far too many games like that :o
I had to skip a Cod level at the end of Act 1 I think. You start off in a helicopter and have to clear off some roofs of baddies. I die 5 seconds in without having seen wtf took me out. I gave up after 50 odd tries and chose another later level and did that no sweat lol
I was stuck on that bit until DannyJo told me how to do it. It is all about Flashbangs and the Grenade Launcher. Also use the auto aim where possible.
Hehe did that bit on my 5th attempt tonight :)
Just did it, you definately need patience in the Final tunnels and the silo parts. Found it was much quicker you go totally prone and edge your way around the corner. Also, you can get away with shooting a single guy behind the pile of boxes. Using this method I even got both checkpoints with 15 seconds to spare. After the bit where the metal doors open (very slowly may i add, wasting a good 20 seconds) the level is quit easy.
The final level was epic too, although surprisingly forgiving for a final level.
Thats what I found, I most of spent a good hour trying to do the final bit with the tunnels either side in the end i read (here i think) about going prone. Tried that did it first time no problem. Then on the level is a piece of cake.
