cod4 rank qestion
12 Jun 2007
Ireland
well reformated my pc installed cod4 my rank is back to lvl 1. its a bit stupid as i thought i created profile but then it means i created profile to my self not in internet so then its possible to gets someone saved profile lvl 55 and just change name as yours?
i dont want to hack in servers, i was thinking to get profile from friend put it in directory load the game change the name would it work?
I heard the multiplayer stats are locked to your specific CD-KEY, so that your mate's stats will not work on your machine unless you both share the same key which you're not supposed to.
Unfortunately it also means you'll have to look after your own profile and back it up before you reinstall games and windows.
getting the challenges it another matter, getting the golden ak47 takes quite a while, 150 headshots with each assault rifle takes a while
Erm you don't hack into anything
You just download a new mpdata file + change the cdkey in registry.
Then load up the game and change the cdkey back to yours, thats is it really tbh
sid
