Cod4 Xp help
6 Jan 2006
Newcastle upon Tyne
How do you keep them? Ive been playing on and off all day and every time I go on my XP is down to lvl 1 again :confused:
Thanks
Right, the trouble is Ive found out that I keep getting disconnected from live. Not sure why butI can sign straight back in so there doesnt seem to be a connection problem?
Im only using a trial xbox live so will that make a difference?
Thanks
If you keep getting disconnected chances are that the xp's are not registering at the end of the game. The fact that you are on a trial should not make any difference.
Yeah thats what I thought. Just tried again now, played one match and then left and got up to lvl 2 but then when I went back to the lobby it said I must have an active connection to play xbox live
Then when I went back in my xp is back down to 1?
Dont think there is anything wrong with my connection but can you think of anything to checkl?
The connection is hard wired and not wireless!
I lost my connection last night at the end of quite a long stint of games, dropped back down to rank 39 from 41. Annoying, mainly as i lost my 3 frag :rolleyes:
